Mandatory tools
In this chapter, we'll explain what tools you'll need to assemble your ByteBoi.
In case you got the ByteBoi kit without the Tools pack, this is a good time to
- Glasses
- Cutter pliers
- Small screwdriver
- Replacement soldering tips
- Lead-free solder
- Soldering stand
- Sponge
- Soldering iron
For ByteBoi's assembly, any entry-level soldering iron will suffice.
Soldering sponge
Diagonal cutter pliers
Standard cross screwdriver
