Additional useful tools
![Helping hand with a lot of additional tools](https://api.circuitmess.com/1637319905966-image.png)
Multimeter
![Multimeter](https://api.circuitmess.com/1637319948102-image.png)
Solder wick
![Solder wick](https://api.circuitmess.com/1637320335418-image.png)
