Open your Wheelson box and check if you have all the components. Make sure to lay it all on a clean surface where you can inspect if everything is there according to the photo and the list below.
If something is missing, please contact us at contact@circuitmess.com. Send us a photo of everything that came in the box, and we'll get back to you as soon as possible to resolve the issue!
- Main circuit board – connects everything together, has a dual-core processor with Wi-Fi & Bluetooth, and a battery charging circuit
- Camera and headlights board
- Display board – 128*160 TFT color display
- Li-Po battery
- Four electromotors
- Four Wheels
- Robot’s plastic chassis
- Two bags of other small components such as pushbuttons, nuts, and bolts
- USB-C cable for charging and programming the device
- ArUco markers
Check all the small components
- Male pin header
- Black nylon spacers (x2)
- Switch button
- White LEDs (x2)
- JST connector (x6)
- Small black pushbuttons (x7)
- Small black button caps (x7)
- Brass spacers (x3)
- Resistors (x2)
- Metal nuts (x12)
- Medium metal bolts (x3)
- Small metal bolts (x3)
- Big metal bolts (x8)
- JST cables (x4)
- JST cable male/male
