Wheelson's anatomy
Welcome to Wheelson's anatomy guide!
Whether you already assembled your Wheelson or not, this is going to be a helpful guide where you’ll learn a bit more about the soldered components, small connections, LED lights, and drivers.
Exploring the board
PCB stands for a printed circuit board. Basically, this fiberglass board has copper traces on it, some protective paint, and insulating material.
Thanks to all the copper leads on the board, all the connected or soldered components can communicate with each other.
Without it, Wheelson couldn't move his motors, the display wouldn’t react after any input from the buttons and we wouldn't be able to read the camera feed.
Just like with other CircuitMess devices like Nibble or Spencer, we want our components not only to work wonders but to look cool as well! Therefore, we designed some pretty fun patterns that you can see on the back of the board.
Take a closer look at the design on the back of the board
ESP-WROOM-32
This microcontroller runs everything, and you could say that this is Wheelson's brain. ESP-WROOM-32 is a powerful module mainly used for sound encoding and streaming music. It is reasonably priced considering all its abilities, including the ability to connect to Wi-Fi.
ESP-WROOM-32 also controls pictures on display and LED lights.
Due to its complexity and sensitivity, this module is already connected to Wheelson's main board.
Reset Button
This one’s pretty self-explanatory - the reset button is used for resetting your Wheelson. You can find this useful in case something gets frozen (which is hopefully never).
USB-C connector
This connector on the top side of the board is used for charging and connecting Wheelson to the computer. Once you connect it to your PC, you’ll be able to program it in CircuitBlocks - a graphical programming interface that helps newbies get into embedded programming.
Battery connector
This connector, on the right side of the board, is used for connecting the LiPo battery to your wheelson. Without the battery, it wouldn't be able to go on long drives!
Motors + Motor Connectors
Motor connectors are located on the bottom side of the board. Each connector is connected to one motor that is later assembled.
The motors, one per wheel, is what gives Wheelson its ability to move around.
White LED
These LED lights are what allows Wheelson to navigate in the dark. They are the headlights and are right next to the camera!
OV2640 Camera
The OV2640 camera is the same as Wheelsons eyes - without it, he wouldn't be able to see. This allows Wheelson to look at his surroundings and decide which way to go. Without it, he would be driving blind.
It also allows Wheelson to be able to read and scan QR codes, recognize different simple objects using a camera and image processing algorithms and drive around autonomously.
On this display, you’ll be able to see what wheelson sees! When applying different filters and computer vision algorithms, you’ll see a different output on the screen so that you can understand how robots see and interpret the world around them.
Display - 128*160 TFT color display
Wheelson's display is connected to its own small board that is soldered to the mainboard. Many pins need to be connected due to the complexity of the component itself. Don’t worry. Guides that explain this step are quite simple, so we hope you’ll actually enjoy the process of soldering this one.
These buttons allow you to navigate through Wheelsons menu, send him in different directions and so much more!
Fun fact
The same display is used in the CircuitMess Ringo kit!
