Assembly
Casing up your Vatreni Token
It's time to assemble your Vatreni Token!
Don't worry, this is a very simple procedure.
The first thing you'll have to do is put batteries in their place.
This part will require the following components:
![random image](https://api.circuitmess.com/1662462875805-dsc04895-4_1280x883.jpg)
It is easiest to place the battery board on a flat surface and then place the batteries on the board's silver circles.
If you look closely at your batteries, you'll notice + and - signs on them. These signs mark polarity, and it's very important for them to be placed correctly on the board; otherwise, your device won't work.
This is where you'll put the battery, with the + sign facing up.
![random image](https://api.circuitmess.com/1662463120551-dsc04899_1280x851.jpg)
You can also take the other board from the kit (the one with + and - signs on it) and put it on top of the first board.This will give you an idea of how to properly place the batteries.
![random image](https://api.circuitmess.com/1662463195307-dsc04922_1280x875.jpg)
Place the boards one on top of the other just like this:
![random image](https://api.circuitmess.com/1662463658582-dsc04929-3_1280x877.jpg)
![random image](https://api.circuitmess.com/1662463685602-dsc04939_1280x889.jpg)
Take the screwdriver and four silver bolts now.
Tighten the bolt in one of the four holes.
![random image](https://api.circuitmess.com/1662463856564-dsc04943_1280x854.jpg)
![random image](https://api.circuitmess.com/1662463865106-dsc04955_1280x893.jpg)
Repeat this step for the remaining three bolts.
Your Vatreni Token should look like this by now:
![random image](https://api.circuitmess.com/1662463932458-dsc04966_1280x785.jpg)
Congrats!
You successfully assembled your Vatreni Token!
In the following chapter, we will show you how to turn it on, and double-check that you did everything correctly.
