Additional, useful tools
![Helping hand with a lot of additional tools](https://api.circuitmess.com/1607698646042-1586968143197-41.jpg)
Multimeter
![Multimeter](https://api.circuitmess.com/1607698691434-1586968189709-42.jpg)
Solder wick
![Solder wick](https://api.circuitmess.com/1607698730605-1586968205966-43.jpg)
