Checking the firmware updates
In this little tutorial, you’re going to learn how to get the latest updates for your Ringo.
Whether you’ve worked your magic and uploaded something of your own on your phone and want to return it all to how it was, or you just want to get that latest implemented feature, the process is the same (and pretty easy as well!).
There are two main ways to do this and they’re all quite simple. One of those includes the use of the computer while one uses just the phone.
Two ways to do it are:
- Ringo’s ‘Check for update’ option
- CircuitBlocks’ ‘Restore Ringo firmware’ button
They are ordered from the simplest to the most complicated so if you're unsure which one to pick, try with the first one - it is pretty straight forward!
