Minor details
Firstly, if you have received a SIM card with your CircuitMess Ringo kit, take it out and pop it out at the 2nd smallest size (micro SIM).
If you didn’t receive a SIM card with your kit, or if you don’t have one that you can use, don’t worry, your Ringo can function just fine without a SIM card (except for calls and messages, duh!).
![random image](https://api.circuitmess.com/1586972632428-DSC05993_1024x683crop.jpg)
Still, we advise that you should insert a SIM card if you have one before going further.
![random image](https://api.circuitmess.com/1586972541871-DSC05948_1024x683.jpg)
![You need Micro SIM - make sure to get the right adapter](https://api.circuitmess.com/1586972552029-SIMt.png)
The SIM card slot is located on the left side of the device, and you need to insert it so that the notch on the SIM card faces upwards (check the picture).
When inserting it you should hear a click when it sits in the slot.
The Micro SIM slot has a push-push mechanism (push when inserting and push when removing).
NOTE: SIM can be inserted in multiple ways but it will only work if it’s inserted the right way. After inserting the SIM card, restart the phone so that the SIM module can reload the card.
![random image](https://api.circuitmess.com/1586972578036-DSC05950_1024x683.jpg)
![random image](https://api.circuitmess.com/1586972607588-SIM-Final-v2-1.jpg)
IMPORTANT: Before turning your Ringo on, we recommend charging your phone for at least one hour.
The batteries come discharged in order to preserve their chemical composition.
![random image](https://api.circuitmess.com/1586972618188-DSC05987_1024x683crop.jpg)
After it had been charging for a while, press the ON button on the bottom right side of the phone.
Your Ringo should power on and boot into the Startup wizard.
Follow the on-screen instructions of the startup wizard to check if everything works right.
![random image](https://api.circuitmess.com/1586972642472-DSC05999_1024x683crop.jpg)
In case something is wrong or you have any questions about the assembly process, please feel free to let us know at contact@circuitmess.com. Also, any feedback that you give is extremely useful to us so we can make this guide and the Ringo kit even better.
Your phone is now up and running! Bravo!
Learn how to code your Ringo in CircuitBlocks here
In the meantime, we invite you to join our Discord channel and Facebook group where you'll be able to share ideas, photos, and feedback with fellow makers and get exclusive news from CircuitMess.
