Electronics 101
1. Circuit board
The black robot-shaped thingy you've gotten in your kit is called a circuit board.
![random image](https://api.circuitmess.com/1638197015553-1638019107974-dsc00155_1272x960_1272x960.jpg)
What does it do?
Where are PCBs used?
They’re used everywhere! In your phone, in your laptop, in your refrigerator, air conditioner. Basically, every electronic device you use has a unique printed circuit board that makes it work.
Did you know?
![random image](https://api.circuitmess.com/1638197049684-image.png)
2. Resistors
We call these legs “component leads”.
![random image](https://api.circuitmess.com/1638197125855-1638017819693-dsc00142_1280x825_1280x825.jpg)
Resistance
Resistors have a property of resistance - they lower the amount of electrical energy flowing through the circuit. They “resist” the flow of electrical energy.
![random image](https://api.circuitmess.com/1638197145142-image.png)
This is Georg Simon Ohm:
![random image](https://api.circuitmess.com/1638197155176-image.png)
3. 3V coin cell battery
You will see the number of volts written on almost every battery as it’s one of the most important pieces of information about the battery.
For example, a mobile phone has a battery of 3.7 volts, and a car has a battery with the voltage of 12 volts
Useful tip:
This particular battery size and model is called a CR2032 coin cell battery.
![random image](https://api.circuitmess.com/1638197266197-sd_1280x815.jpg)
4. Battery holder
This battery holder is a plastic electronic component with two metal springy legs.
It is used for holding the coin cell battery in place and connecting it with the rest of the electronic circuit.
![random image](https://api.circuitmess.com/1638197476591-sd_1280x804.jpg)
5. Red LEDs
These electronic components will make your RESISTRON’s eyes light up.
LEDs convert electrical energy into visible light.
![random image](https://api.circuitmess.com/1638197689104-image.png)
Watch out - LEDs are polarized!
Light-emitting diodes (LEDs) are polarized.
Because of this, you need to pay attention to how you are going to place your LED in the electronic circuit.
They mark polarity!
![random image](https://api.circuitmess.com/1638198050972-sd_1280x814.jpg)
Oh no! The coin cell battery supplied with your RESISTRON is too much for the poor little LEDs.
But don't worry, we sent resistors to the rescue!
Historical fun facts:
A Russian inventor Oleg Vladimirovich Losev made the first LED in 1927.
![random image](https://api.circuitmess.com/1638198257086-image.png)
Did you know?
LED lightbulbs are the most efficient type of lightbulbs.
Unlike “regular” “old” bulbs (we call these incandescent lightbulbs), which release 90% of their energy as heat, LEDs use energy far more efficiently with very little wasted heat.
6. Variable resistor
A variable resistor is a resistor of which the electric resistance value can be adjusted.
They come in different shapes and sizes. The one included in your box is shaped like a knob that can be turned. By turning the knob, the resistor’s resistance will change.
![random image](https://api.circuitmess.com/1638198592936-sasd_1280x813.jpg)
You will use this one for regulating the brightness of the LEDs in REISTRON’s eyes.
