Electronics 101
1. Circuit board
The yellow bee-shaped thingy you've gotten in your kit is called a circuit board.
![random image](https://api.circuitmess.com/1638177047587-1637932404227-dsc00271_1280x921_1280x921.jpg)
Where are PCBs used?
They’re used everywhere!
Did you know?
![random image](https://api.circuitmess.com/1638112803248-board-electronics-computer-data-processing-50711_1280x870.jpeg)
We call these legs "component leads".
This is Georg Simon Ohm:
You will see the number of volts written on almost every battery as it’s one of the most important pieces of information about the battery.
For example, a mobile phone has a battery of 3.7 volts, and a car has a battery of 12 volts.
Useful tip:
This particular battery size and model is called a CR2032 coin cell battery.
This particular motor type has a special name - an ERM motor.
An ERM motor has an off-center load, and when it rotates, the centripetal force (a force that makes a body follow a curved path) causes the motor to move.
This motor has two wires coming out of it.
The colors of the wires (red and blue) represent the polarity of the wires: blue is negative (-), and red is positive (+).
These wires are used for connecting the motor to the power source (battery) and powering the motor.
This is an electronic symbol of a motor:
Historical fun fact:
What does it do?
Did you know?
2. Resistors
![random image](https://api.circuitmess.com/1638177078378-1637934304146-dsc00281_1280x869_1280x869.jpg)
Resistance
![random image](https://api.circuitmess.com/1638112565971-360_f_337277306_bowr2gmishgzyfqrnyeynmx2uvp7ntxe_1280x853.jpg)
![random image](https://api.circuitmess.com/1638112693539-20740-0-georg-si-jpg-1533200480281_756x960.jpg)
3. 3V coin cell battery
Useful tip:
![random image](https://api.circuitmess.com/1638272438602-untitleddshdj_1280x934.jpg)
4. Battery holder
This battery holder is a plastic electronic component with two springy metal legs.
It is used for holding the coin cell battery in place and connecting it with the rest
of the electronic circuit.
![random image](https://api.circuitmess.com/1638181179393-1637933839201-dsc00274_1280x860_1280x860.jpg)
5. Vibration motor
This component makes MR. BEE vibrate and move around.
![random image](https://api.circuitmess.com/1638275693593-ddaljankjdn_1280x896.jpg)
![random image](https://api.circuitmess.com/1638199894845-materijali_web-14_1280x737.jpg)
6. Switch
![random image](https://api.circuitmess.com/1638180376864-untitled_1230x960.jpg)
