How do I solder?
One of the things you'll do as a part of Marv's assembly process is soldering!
- Adafruit’s standard soldering tutorial - A great and thorough video tutorial. An absolute must-read, even if you know how to solder. Make sure to check the “common soldering mistakes” section at the end.
![random image](https://api.circuitmess.com/1638009161462-dsc00108_1280x889_1280x889.jpg)
![](https://cdn.shopify.com/s/files/1/0552/3269/2430/files/Lemljenje_01_2.jpg?v=1682675944)
![](https://cdn.shopify.com/s/files/1/0552/3269/2430/files/Lemljenje_02_2.jpg?v=1682675960)
Know how much solder is needed! Make sure to put just enough solder.
![random image](https://api.circuitmess.com/1638009446212-image.png)
Step 1 - plug it in
![random image](https://api.circuitmess.com/1638009472653-image.png)
![random image](https://api.circuitmess.com/1638009508836-image.png)
![random image](https://api.circuitmess.com/1638009546321-image.png)
