Additional useful tools
Desoldering vacuum tool (aka. solder sucker)
This tool is useful for cleaning up soldering mistakes but is not 100% necessary for assembling your MAKERbuino.
If you plan to do some hacking, modding, or any kind of hardware repair or rework in the future, buying this one is a good idea.
Helping third hand with magnification
This one is also not necessary but will make your life (and soldering) much easier when it comes to assembling and/or repairing devices more complicated than MAKERbuino.
![random image](https://api.circuitmess.com/1587027989669-41.jpg)
Multimeter
It will prove useful for testing some tricky connections and measuring supply voltage. Besides that, a good multimeter can help you test resistors, transistors, diodes, capacitors, measure the current, and do all sorts of other useful things.
![random image](https://api.circuitmess.com/1587028007660-42.jpg)
Solder wick
You can use it along with the desoldering vacuum tool to clean up soldering mistakes. It will clean the excess solder from the places unreachable with a regular desoldering vacuum tool.
![random image](https://api.circuitmess.com/1587028020867-43.jpg)
