Mandatory tools
In this chapter, we'll explain what tools you'll need to assemble your Jay-D.
In case you got the Jay-D kit without the Tools pack, this is a good time to
![](https://cdn.shopify.com/s/files/1/0552/3269/2430/files/2_3.png?v=1689148326)
- Glasses
- Cutter pliers
- Small screwdriver
- Replacement soldering tips
- Lead-free solder
- Soldering stand
- Sponge
- Soldering iron
For Jay-D's assembly, any entry-level soldering iron will suffice.
![](https://cdn.shopify.com/s/files/1/0552/3269/2430/files/DSC00696_1280x853_b5af1d4a-c136-4f6d-8fc7-5d3309ef92ec.jpg?v=1685955308)
Soldering sponge
Diagonal cutter pliers
![](https://cdn.shopify.com/s/files/1/0552/3269/2430/files/1638022915722-image.png?v=1685820009)
Standard cross screwdriver
![random image](https://api.circuitmess.com/1658226097241-image.png)
