How does Frank work-1?
1. Circuit board
The green thingy you've gotten in your kit is called a circuit board.
Professionals call this a printed circuit board or PCB.
What does it do?
  1. It holds all the electronic components in place
  2. It provides electrical connections between the electronic components.
Where are PCBs used?
They’re used everywhere!
Did you know?
2. Electric motor
An electric motor is an electrical machine that converts electrical energy into mechanical energy.
Its purpose is to generate linear or rotary force (torque) intended to drive external mechanisms, such as a fan or an elevator.
It is designed for continuous rotation or for linear movement over a significant distance.
Comprising of four key components, the electric motor consists of the rotor (the moving part) and the stator (the stationary part), along with the armature and commutator as its electrical elements.
3. Batteries
You will see the number of volts written on almost every battery as it’s one of the
most important pieces of information about the battery.
For example, a mobile phone has a battery of 3.7 volts, and a car has a battery with a voltage of 12 volts.
4. Switch
The switch you got in your kit helps you turn Frank on and off. You can easily do so with one simple push.
A switch controls the flow of power to an electric device - in other words, it connects and disconnects an electrical circuit.
Historical fun fact:
An electrical switch was invented in 1884 by John Henry Holmes, who used it
for turning lights on and off.
5. LEDs
LEDs convert electrical energy into visible light.
Oh no!
The coin cell battery supplied with your Frank is too much for the poor little LEDs.
But don't worry, we sent resistors to the rescue!
Did you know?
LED lightbulbs are the most efficient type of lightbulbs.
Unlike “regular” “old”  bulbs (we call these incandescent lightbulbs), which release 90% of their energy as heat, LEDs use energy far more efficiently with very little wasted heat.
