Meet the tools!
In this chapter, we'll explain what tools you'll need to assemble your CircuitPet.
In case you got the CircuitPet kit without the Tools pack, this is a good time to
1. Glasses
2. Cutter pliers
3. Small screwdriver
4. Replacement soldering tips
5. Lead-free solder
6. Soldering stand
7. Sponge
8. Soldering iron
For CircuitPet's assembly, any entry-level soldering iron will suffice.
Soldering sponge
Diagonal cutter pliers
Standard cross screwdriver
