Write on the screen
And the final sketch will be something simple and enjoyable.
That is, after the code is executed, something should be written on the screen.
Try to code the text by yourself before checking our code below.
Were you successful?
All of the blocks can be found in the "Display" block section.
This is what our code looks like:
Click on the Run code and check it out.
