Chatter Arduino Uploading Code
After setting everything up, we can move on to uploading code to your Chatter.
Choose what to upload
Next, in Arduino go to Tools -> Port, and select the port your Chatter is connected to. It’s usually the only option available.
And that's it! You have now uploaded your code to the Chatter. Great job!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 |
#include <Chatter.h> Display* display; Sprite* sprite; void setup() { Chatter.begin(); display = Chatter.getDisplay(); sprite = display->getBaseSprite(); sprite->clear(TFT_BLACK); sprite->setTextColor(TFT_WHITE); sprite->setTextFont(2); sprite->setCursor(0,0); sprite->print("Hello World!"); display->commit(); } void loop() { LoopManager::loop(); } |
Let's make sure your Chatter is ready for the upload!
Turn on your Chatter and plug it into your computer with a USB cable.
