How do I solder?
One of the things you'll do as a part of Capacitron's assembly process is soldering!
Sparkfun’s standard soldering tutorial - A detailed tutorial made by Sparkfun.
![random image](https://api.circuitmess.com/1638024260961-dsc00058c_1280x929.jpg)
![](https://cdn.shopify.com/s/files/1/0552/3269/2430/files/Lemljenje_01_2.jpg?v=1682675944)
![](https://cdn.shopify.com/s/files/1/0552/3269/2430/files/Lemljenje_02_2.jpg?v=1682675960)
Know how much solder is needed! Make sure to put just enough solder.
![random image](https://api.circuitmess.com/1638024437719-image.png)
Step 1 - plug it in
![random image](https://api.circuitmess.com/1638024458881-image.png)
![random image](https://api.circuitmess.com/1638024499673-image.png)
![random image](https://api.circuitmess.com/1638024539730-image.png)
