Electronics 101
1. Circuit board
The red head-shaped thingy you've gotten in your kit is called a circuit board.
What does it do?
- It holds all the electronic components in place
Where are PCBs used?
They’re used everywhere!
Did you know?
2. Resistors
We call these legs “component leads”.
Resistance
Resistors have a property of resistance- they lower the amount of electrical energy flowing through the circuit. They “resist” the flow of electrical energy.
This is Georg Simon Ohm:
3. 3V coin cell battery
You will see the number of volts written on almost every battery as it’s one of the
most important pieces of information about the battery.
For example, a mobile phone has a battery of 3.7 volts, and a car has a battery with a voltage of 12 volts.
Useful tip:
4. Battery holder
This battery holder is a plastic electronic component with two metal springy legs.
It is used for holding the coin cell battery in place and connecting it with the rest of the electronic circuit.
5. Switch
The switch you got in your kit helps you turn CAPACITRON on and off. You can easily do so with one simple push.
Historical fun fact:
An electrical switch was invented in 1884 by John Henry Holmes, who used it
for turning lights on and off.
6. Pushbuttons
A pushbutton switch is a small, sealed mechanism that completes an electric circuit when you press on it.
When a pushbutton is pressed, a small metal spring inside makes contact with two wires, allowing electrical energy to flow.
When you release your finger from the pushbutton, the spring retracts, the electrical contact is interrupted, and electrical energy won't flow through the switch.
What's the difference between a switch and a pushbutton?
Switches have an on and off state that can be switched between by pushing the switch with your finger.
A pushbutton also has two states - on and off. A pushbutton will change its state if you push it with your finger, but it will automatically retract back to its original state when you remove your finger.
7. Red LEDs
These electronic components will make your CAPACITRON’s eyes light up.
LEDs convert electrical energy into visible light.
Watch out - LEDs are polarized!
Light-emitting diodes (LEDs) are polarized.
Because of this, you need to pay attention to how you are going to place your LED in the electronic circuit.
They mark polarity!
Oh no! The coin cell battery supplied with your CAPACITRON is too much for the poor little LEDs.
But don't worry, we sent resistors to the rescue!
Historical fun facts:
A Russian inventor Oleg Vladimirovich Losev made the first LED in 1927.
Did you know?
LED lightbulbs are the most efficient type of lightbulbs.
Unlike “regular” “old” bulbs (we call these incandescent lightbulbs), which release 90% of their energy as heat, LEDs use energy far more efficiently with very little wasted heat.
8. 2200uF capacitor
This is an electronic symbol of a capacitor:
A capacitor can absorb energy from a circuit and store it temporarily.
We call this property - capacitance.
The unit of capacitance is called Farad (we use the letter F as a short for Farads).
This unit was named after physicist Michael Faraday.
Capacitors were discovered by Pieter van Musschenbroek a looong time ago - in 1746.
