How do I solder?
One of the things you'll do as a part of Bob's assembly process is soldering!
Sparkfun’s standard soldering tutorial - A detailed tutorial made by Sparkfun.
- Never inhale the dust and the fumes produced by the soldering iron!
Know how much solder is needed! Make sure to put just enough solder.
The soldering iron is very easy to use when used properly.
Step 1 - plug it in
